maf screen
Old Sep 12, 2003 | 10:46 PM
2002 3.8's Avatar
maf screen
how do you remove the maf screen, and whats the point? will it hurt anything, will it make any difference in performance?
Old Sep 12, 2003 | 10:50 PM
DomesticViolence's Avatar
Re: maf screen
not enough performance to justify removing it and risking something getting inside the motor.
Old Sep 13, 2003 | 05:21 AM
oil pan 4's Avatar
for an allmost stock engine just leave it in.
Old Sep 22, 2003 | 04:33 PM
redcamaro's Avatar
i've been running my car without it for more than a year without any problems at all. corvettes doesn't have them and they run fine. i took mine out without any damage just in case i needed to put it back. is easy to remove.
Take off the lid and the tubes running to the TB.
you would the screen in the TB. Find a small pair of needle nose pliers. Place the tips on the pliers into the small holes in the retaining ring. Lightly sqeeze the pliers and pull the ring out, then carefully take the screen out.
wait for the next morning. then start your engine and wait for like 3 min. then your intake would be a little hot. that is when you take the screen out. it would be easy to remove it when the intake is hot.
you will notice a change on the exhaut tone. get a little deeper, and you would notice like more pull when reving high.
hope this help
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
