lt1 swap into a 99 v6
Old Jun 9, 2010 | 02:32 AM
blackz151's Avatar
I know this topic is coverd over and over. My question is i have a 96 with an lt1 in it. It got hit. I have a line on a 99 v6. Can i swap all my stuff over to the 99 or does it have to be a yonger year? Thanks guys
Old Jun 9, 2010 | 11:10 PM
coco95z28's Avatar
no it will fit fine, you just need the wiring and new cluster, also most v6's didnt come with a posi rear end so you should swap that too. i also think that the suspention has too be switched over cause of the weaker springs on the v6's
i think its the same tranny in all 94-02 cars right? (93's were 4l60 though)
if your talking auto's................
Old Jun 17, 2010 | 04:16 AM
95camaroinok's Avatar
You'll need your drivetrain, engine cradle for an LT1,( you didnt state where it was hit or how bad) your wiring/computer, and a 97 Instrument cluster if you dont want to change the entire dash. It can be done, most people will probably tell you to swap to an LS1, but I say DO IT! If you have the know how, ability, and obviously the parts, you can make it happen. Its not THAT complicated. You may need to do some more searching on the wiring. You might have to change the entire car harness, Im not sure how it'll interface with the older harness etc with the body control module and lighting. Just do some searching.
Old Jun 24, 2010 | 04:35 PM
94EvilZ28's Avatar
same situation...and have all the parts...but need info on the wiring and the dash stuff...can anyone provide anymore info on this?
Old Jun 29, 2010 | 11:04 PM
94EvilZ28's Avatar
Anything on the wiring people?
James
Old Jul 19, 2010 | 03:05 AM
Helltrooper509's Avatar
How about fuel lines and rear end? I have a similar situation, I have a 96 Z28 and found a 98 v6 camaro.
Old Aug 15, 2010 | 12:31 AM
94EvilZ28's Avatar
Nothing people?
Noer
Feb 28, 2015 11:29 AM
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
