looking for OBD1 laptop software
Hey guys I'm looking for an OBD1 software program that interfaces with our L32 v6's to run some diagnostics. I've found plenty for the V8 but us 6ers need one too. If any of you know of one, could you please email me the location or any info that you have...Thanks!
I haven't really heard of anything, I just bought a tool that is basically a fancy "jumper" but it does allow some fancy stuff on testing the abs system and gives a coupel readings if the computer is running lean or rich.
But basicaly tells ou if a sensor is good or bad, not really giveing "real time" readings like oil pressure, temp, readings form sensors.
Is this good enough for you if so I will go look up the name of the reader, but I have yet to get it to work even though it says specifically it works on my 94 3.4L v6 Camaro.
I'll figure it out someday.
whitehooptie
Aug 10, 2015 07:02 AM
