Intake manifold
Old Jan 1, 2005 | 08:44 PM
orange57's Avatar
Intake manifold
i have a 2000 Camaro 3800 mounted in my 1977 MGB, and was looking at where the thorttle body is mounted. it looks like i'm going to have some problems with a radiator gettting put in there. are there any intake manifolds taht will alow me to switch where the throttle body/air intake is located on the engine? i was looking at my 1989 Oldsmobile, which also has the 3800, and the intake comes from the other side. same thing with my 2003 MonteCarlo SS, which has the 3800 also. any help would be appreciated.
matt
Old Jan 1, 2005 | 11:57 PM
Camabird's Avatar
Re: Intake manifold
grand prix that are not supercharged and bonnevilles that arent superchanged have the motor as well. not quite the same setup bc theyre fwd, maybe its what youre looking for?
Old Jan 2, 2005 | 01:09 AM
orange57's Avatar
Re: Intake manifold
i'm just wondering if i can used the manifold off of one of those cars on a 2000 camaro engine. would it be interchangable?
matt
Old Jan 3, 2005 | 04:04 PM
94m5's Avatar
Re: Intake manifold
The supercharger will also move the airintake to the rear. But you could still run into a pulley/radiator problem.
You should be ok with any of them, but I CAN'T say for sure. Some where in the 3.8's history they changed designs on the top end.
Old Jan 3, 2005 | 10:20 PM
orange57's Avatar
Re: Intake manifold
i'm wondering if all the SeriesII are the same, and all the older ones are the same. looking at the throttle body on my Monte Carlo, and the camaro engine i have, and the Oldsmobile i have, the Monte and Camaro look real similar, just on differnt sides, the olds one looks quite a bit different. going to wait till someone can let me know for sure before i try to find a manifold.
thanks for the help guys.
matt
Old Jan 6, 2005 | 02:16 PM
Tarnsman's Avatar
Re: Intake manifold
Have you looked at the upper intake manifold from a 95-98 3800 F-body? It is different from the 2000.
Old Jan 8, 2005 | 09:22 PM
orange57's Avatar
Re: Intake manifold
no, i mite have to see if i can find one around, or does anyone have a pic?
matt
Old Jan 11, 2005 | 12:18 PM
Tru2Chevy's Avatar
Re: Intake manifold
Here are some iffy pics of my friend's '98 camaro....they will give you an idea of the manifold difference (it points down and towards the driver's side.
http://www.cardomain.com/memberpage/659591/3
- Justin
Old Jan 11, 2005 | 11:53 PM
orange57's Avatar
Re: Intake manifold
i deffinitly think i'm going to have to try to find an intake manifold off of like a frontwheel drive car with the 3800. it would work for my application a lot better i think.
matt
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
