I need stock 5-speed ger ratios, and stock 3.4L cam specs...
I found a pretty cool drag racing game at Target for $10, doesn't have a 3.4L, but has a 3.1L and I can adjust cam, valves, bore and stroke and I cna put this motor in a manual trannied 4th gen f-body that I got to be the same weight as my car.
jsut need these things to get it very similar to a stock 3.4L
stock gear ratios in a 5-speed
And cam specs.
Thank you, all my books are at my place and i am spending the night at the girlfriend's place.
And cam specs.
lets see,
the stock cam is:
196 / 203 dur. @ .050, .394/.410 valve lift
and the tranny(via dominics website http://angelfire.com/my/fastcar/) :
1st Gear 3.75 according to RPO
2nd Gear 2.19
3rd Gear 1.41
4th Gear 1.00
5th Gear (Final Drive) 0.76 according to RPO
Reverse 3.53
seems more like a truck tranny
the stock cam is:
2nd Gear 2.19
3rd Gear 1.41
4th Gear 1.00
Reverse 3.53
Location: carbondale IL \ Alton IL (outside St Louie MO)
jeremy , where did you get your specs for the stock cam?
firebird V6.com's technical database says
1993 - 1995 Stock
Intake Duration 195 degrees
Exhaust Duration 201 degrees
Camshaft Intake Lift 0.263 in
Camshaft Exhaust Lift 0.273 in
Lobe Separation 109 degrees
Intake Centerline 111.5 degrees
Lifter Hydraulic Flat Tappet
Rocker Arm Ratio 1.5:1
Intake Lift 0.394 in
Exhaust Lift 0.409 in
1993 - 1995 Stock
1993 - 1995 Stock
1993 - 1995 Stock
hehe....
Eithere way don't worry too much, I'll be moving my Ps2 to my place tonight I have all the specs i need.
I ran it under a generic stock street strip cam, they have in the game and it was around 155hp, and 196 torque, so not far off, probable more accurate then GM's rating.
I had some problems with the tranny and other stuff though... I used a stock Borgwarner T5 setting they had and first gear was 2.75.
hehe funny thing is I miss read how they had the thing where you can select your tires, and I put like 34 in. tall tires on the left side, and skinnies on the right side
