How to change water pump??
Well my water pump is leaking and the dealership said it would be close to 500 to change it out. Is it really that hard to change it out on a 98 Camaro?? Any help is appreciated. Thanks.
Re: How to change water pump??
Buy a haynes repair manual from auto zone or some where and follow it step by step. Not really sure how hard it is on the 3.8, but should not be to hard if you have some basic tools and take your time you will be fine.. I think the pump is about a 100 bux and you should change your thermastat while you are at it if you havent yet
man its very easy
take off your intake and allt hat plastic crap get it tout the way
its rightin the center there 4 bolts holding the pully remove those and you can see all the bolts take them out and remove it
Magenta_Hearts
Mar 29, 2017 08:54 PM
Sandersen511
Jan 13, 2015 03:49 PM
