Hi-flow cat
Old Feb 12, 2003 | 01:44 PM
Tuitsui's Avatar
Hi-flow cat
Where is the best place to buy one?
Also what would gains be?
Old Feb 12, 2003 | 02:58 PM
ImportKILLER's Avatar
Try summit...
Catco will run you approx. $50
I believe they have it on sale...
Can't tell you on gains, just don't aim too high.
Old Feb 12, 2003 | 03:24 PM
94GrayV6's Avatar
3 rwhp at the most.
Old Feb 12, 2003 | 04:01 PM
MustangEater82's Avatar
Its much better then a stock clogged one... if yours is pretty old I woudl get one, Catco seems to be the chaepest, and differences between Catco and expensive ones are really not worth it.
Old Feb 12, 2003 | 04:21 PM
Tuitsui's Avatar
yea mines got 150k on it and it's all cracked and clogged so will there be any noticable gains and will it sound any different?
Old Feb 12, 2003 | 08:07 PM
94GrayV6's Avatar
You should notice better gas mileage and a little top end gain. As for sound, it depends on what the rest of your exhaust setup is.
Old Feb 12, 2003 | 09:05 PM
Tuitsui's Avatar
well i'm getting a cat back as well
Old Feb 12, 2003 | 09:22 PM
chesee48's Avatar
Originally posted by ImportKILLER
Try summit...
is that they price that summitt has at directly through catco?
Old Feb 13, 2003 | 03:04 PM
KevinAce's Avatar
As far as converters go and catback exhaust, and all that good stuff...what should I go with? Should I replace the stock "Y-Pipe" with an aftermarket with more air flow ability. Does this pipe include cats within it? Any links would be appreciated.
Old Feb 14, 2003 | 02:46 AM
KevinAce's Avatar
Do all Y-Pipes (are there other options, X / H pipes?) come with high performance cats build in?
Old Feb 16, 2003 | 10:11 PM
Shorty95Camaro's Avatar
Ace- I'm not sure about the cat coming with the Y-pipe. I think that it would be separate. Don't they usually sell the Y-pipe with headers?
I don't really know a lot about that aspect of exhaust.
But I've always wanted a cat also, just for the additional sound. I have about 120k on my clock...but i don't think there's anything wrong with mine. So I'm debating about changing it. Would I be able to put this cat in...or would I have to have someone change it for me (and yes I realize all the legal aspects of it).
But would the catco fit nicely in there without too much work?
Old Feb 17, 2003 | 04:33 PM
HPbyChevy's Avatar
Random Technology sells a high flow cat (a little pricey though), I see in the Jeg's catalog Magnaflow is selling a High flow cat. Summit's has Catco's. Research does wonders! Don't get a stiffy when this thing goes on, because your hp gain won't be very noticeable. I had a pro put the cat on for me (because of the legal and emissions b.s. - documentation stands up in court!)
Generally, y-pipes come with headers (not with a cat). Unless you're ordering oem (stock from the dealer - they can send you a y-pipe with a cat welded on -- but who wants stock? )
I'd put a set of headers on, go to bigger y-pipe, add a high flow cat and find a good cat back set-up! Open the exhaust up as much as you can.
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
