HELP voltage gauge going down
Old Sep 23, 2003 | 11:25 AM
01_camaro_DTX's Avatar
I upgraded my sparkplugs to bosh platinum 4's and my cables to msd's 8.5mm. Now suddenly after driving the car for a while when I let go of the gas pedal at about 40 mph my voltage gauge drops to the bottom and my lights dim and the car feels like its going to stall. Also when the car is parked and idle it feels like its going to turn off but it does not. Does any one have an idea of what could this be. Also if I do not use the car for more than 24 hrs it will not start after wards or start very weak. I changed the battery but it still doing the same thing. PLEASE HELP!!!!!!!
Old Sep 24, 2003 | 07:30 AM
Ichoptop's Avatar
I doubt if plugs and wires will do this, mostly a set of quality wires. Check the voltage at the battery with car not running (like first thing in the morning before you start it) Then start it and check the voltage again. At rest the battery should have atleast 12.2 V and running you should be well above 13 V. If you arent then it sounds like the diodes in the Alt are dead. Have the Alternator rebuilt by a reputable shop. It only takes about a half hour and is cheaper then buying a new one.
Formula Steve
Sep 19, 2023 08:31 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
