Help..trouble installing TPS!!!!!!!
Old Aug 13, 2004 | 07:21 PM
95cam3.4's Avatar
I just bought a new throttle position sensor for my 1995 camaro 3.4L and installed it. After installing it the car would idle at 2000rpm...so I took the sensor out to look at it and the little plastic guide tracks were chewed up at the top!!....is there some special way of installing this sensor???
Old Aug 15, 2004 | 11:47 AM
HBHRacing's Avatar
Re: Help..trouble installing TPS!!!!!!!
you see in the sensor how it has a slot? that needs to line up with the part on the TB shaft. you need o be crefull and twist it a little bit untill it falls into place and then tighten it down
Old Aug 15, 2004 | 06:35 PM
95cam3.4's Avatar
Thanks, that's what I thought...id is working but I was just concerned about the tops of the fingers being a little chewed up.
Nov 18, 2023 07:21 PM
jackpawt883
Feb 26, 2015 09:04 PM
grgguy
17
Feb 23, 2015 07:57 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
