HELP please
Old Jul 29, 2003 | 10:40 AM
Green G0blin's Avatar
HELP please
the blinkers in my car dont work!
i put the blinker on and the bulb turns on but it dont blink. all 4 bulbs turn on. i was told to check the flasher..bought a new one..still wont blink.
so im back to the bulbs......
can someone please help me? i need blinkers or the cops will have a fieldday with me....
if i turn on the blinker, it turns on but dont blink, inside the car the lil arrow turns on..no noise no blinking!
Old Jul 29, 2003 | 10:43 AM
1fastV6's Avatar
turn your blinker on off on off on off on off on off.
thats wierd. sorry i cant be of no real help. i have never heard of anybody having that problem.
Old Jul 29, 2003 | 08:20 PM
99blackSS's Avatar
Did you buy the right replacement flasher?
Old Jul 31, 2003 | 07:30 AM
Scammper's Avatar
there is a little relay type thing that you could try replacing. I havent actually done this for my camaro, but in other chevys. I believe it is behind the panel under the steering wheel. I am not sure, but I wanna call it a Wells or Wagner or something like that. The ones I have seen, are little metal cylinders. You just gotta unplug it and plug in the new one. Its been a while, but I think that fixed the no blinking blinker....
Old Jul 31, 2003 | 09:01 AM
camaros_4_lfe's Avatar
both sides or just right or left?
i would change or rotate or clean all the bulbs if its just one side
my car did it all the bulbs worked then i put in new ones and it went away.
Old Jul 31, 2003 | 12:43 PM
gol10dr's Avatar
Well, I had just one doing the same thing(staying on, but not blinking). I changed out the bulbs, the relay under the hood, and now (i just got back from lunch) both sides aren't blinking..
Old Jul 31, 2003 | 01:00 PM
kahouna23's Avatar
The flash relay is located on the drivers side behind a panel where your right knee would be. It's a small silver cylinder about 2" long. It's held in with a pain in the butt clip, but once you get it free it's easy to change out. If you bulbs come on but don't flash......it's definately the relay I'm speaking of. The clicking you normally hear is the relay you need to change. They're only like $5-6 at Pep Boys or wherever you buy parts. If your turning lamps turn on when you use your signal but don't flash....it's not the bulbs, so don't worry about swapping around the bulbs or anything else. Get the relay....and you're golden.
Old Aug 1, 2003 | 07:21 AM
gol10dr's Avatar
Last night I took my dash apart to find the silver relay. I didn't find anything that looked like a silver relay, heck I didn't find anything silver under the dash. What is the relay model number?
Old Aug 1, 2003 | 01:07 PM
PoloGreen 3.4's Avatar
all i did, was beat the **** out of the light, now it works great!
