help me, odd erratic/consistant idle
Old Sep 24, 2003 | 10:42 PM
fourthgen9534's Avatar
Long time since I've posted on here. Anyways, I've got a 95 3.4 maro, t5. For a month or so now it's been idling high(around 2k rpm) when I first crank it, everytime; also just after i take it out of gear to stop at a light. Wierd thing is I can tap the gas pedal(just touch it, not enough to rev it at all) and it will always go back to normal idle(1k) The only thing I know of that's really wrong with the engine is my crankshaft position sensor is broken, and kind of dangling(has been for a few months before this problem though) and I have a new one, just been too caught up in other stuff to put it on. Any ideas?
Thanks,
Lynn
Old Sep 25, 2003 | 02:28 PM
ianwells100's Avatar
my old 95, 3.4 used to have a slightly iffy idle when i first started, so i took out the IAC sensor (on the side of the throttle body, poisitioned slightly above, check your haynes manual), and cleaned it, that fixed it for me... hope this helps
ian
Old Sep 25, 2003 | 06:42 PM
I forgot to mention that I put in a new iac just after it started doing this, no change. thanks
Old Sep 25, 2003 | 11:24 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
pull the PCM fuse , put it back in , start the car... let it run 5 min .. turn it off, wait 5 min, turn it on again.. should reset itself.. turn it off then you should be ready to roll
Old Sep 25, 2003 | 11:26 PM
did that a couple times too.....guess I should've mentioned the stuff I've already tried to correct it
Double aught
Oct 2, 2015 11:29 PM
jayblev95
Sep 26, 2015 09:44 PM
95craz28
11
Sep 12, 2015 07:47 AM
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
