help, im lost
Old Aug 6, 2004 | 02:48 AM
1sicv6's Avatar
help, im lost
ok while driving i noticed a problem. if i punch it or floor it my lights and dash lights dim, as well as the battery gage goes down to the red i had the battery and alternator checked and they are both ok, any other ideas what the problem could be
Old Aug 6, 2004 | 10:34 AM
valter's Avatar
Re: help, im lost
Not sure about it, but it sounds like a bad contact somewhere (check ground and "+" connections from a battery to body/"+" box for corrosion, clean everything, check alt connector), or a bad voltage regulator built-in alternator. I suggest you double check this.
Old Aug 6, 2004 | 10:40 AM
joed4640's Avatar
Re: help, im lost
Originally Posted by valter
__________________
97 TA M6, black with LT4 kit, Edelbrock shorties, Borla-mouth exhaust, Moroso CAI and other goodies.
97 Ford Crown Vic P71, almost stock
96 V6 red firebird, some bolt-ons
98 Jeep WJ 318 cid, Borbet wheels
Hey man, a 98 Grand is a ZJ not a WJ
Sorry to hijack your thread 1sicv6...good luck with your car
Old Aug 6, 2004 | 10:59 AM
valter's Avatar
Smile Re: help, im lost
[QUOTE=joed4640]Hey man, a 98 Grand is a ZJ not a WJ
My mistake Changing sig...
Old Aug 11, 2004 | 01:25 PM
HBHRacing's Avatar
Re: help, im lost
have the system checked by someone else.
also check the condition of the batery termonals.
next make sure that the belt is in good shape, the tentioner is not lose and that the water pump is not driping on the belt
Old Aug 11, 2004 | 02:40 PM
Green97Cam30th's Avatar
Re: help, im lost
do you have underdrive pullies?
Old Aug 12, 2004 | 04:33 AM
1sicv6's Avatar
Re: help, im lost
no car is stock, im gonna check every connection tomorrow, belt is fine too by the way, not loose at all
Old Aug 12, 2004 | 11:22 AM
MustangEater82's Avatar
Re: help, im lost
Check and make sure the terminals are not corroded including the one form the alternator to the battery.
Also like said check the tensionor. Could be putting slack on the belt with the added power, causing alternator not to work.
blac94Z
Nov 4, 2015 01:59 PM
WobblySausage
Oct 7, 2015 02:44 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
