Help on blowing fuses
Old Mar 1, 2004 | 04:03 PM
birdmanwv's Avatar
Just purchased a 95 firebird 3.4 with 60,000 miles. I noticed the defroster and power seats don't work. I pulled off the fuse panel and found no fuse where one should be. I figured it would be an easy fix. I barely started to put the 20 amp fuse in when a spark almost blew my hand off!!! The fuse didn't blow but the spark ate out a nice gouge in it. Needless to say, I didn't try it again.
Am I right to assume that there is a short somewhere in the defroster and/or seat? What would be the fix? Its a convertible top, so the back window is not that big to scrape if I had to!!!
Old Mar 1, 2004 | 09:42 PM
Need4Camaro's Avatar
You did try this with the engine off didn't you? I say try it again with the battery disconnected. No Juice No Blues...
Good luck.
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
