Headlight replacment
Old Jan 12, 2004 | 02:39 AM
jetman624's Avatar
How hard is it to replace the head lights and where would I go to get new ones. Would pep-boys or somthing of that sort be fine? Or is the dealership a better idea?
Old Jan 12, 2004 | 03:18 AM
99blackSS's Avatar
The dealership is always a last resort.
Almost any auto parts store will have the bulbs you need. Not sure what kind of car you have though. If it's a 98-02 Camaro they are very easy to change.
Welcome to the board.
Old Jan 12, 2004 | 06:59 PM
jetman624's Avatar
94 V6
It is a 94 V6.
Old Jan 12, 2004 | 08:00 PM
ImportKILLER's Avatar
93-97 headlights are a piece of cake. There are two torx screws you need to remove in order for the "retainer" to come out and then you pull out the old headlamp, disconnect and then reverse the order. I just replaced my bulbs last night (to higher wattage ) in 5 minutes for both sides.
The top screw is the one on the upper right corner and there is another one that is harder to see underneath to the middle-right.
Old Jan 13, 2004 | 01:27 AM
jetman624's Avatar
where
where did you get your bulbs, higher wattage sounds good. The stoco ones always seemed rather week to me,
Old Jan 14, 2004 | 07:52 AM
94BlackBowtie's Avatar
You just need to find you whatever kind of bulb you want to use in the sizes of 9006 for the low beams, and 9005 for the high beams. Then search the appearance section for directions.
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
