Headlight and Fuel Cleaner
Old May 6, 2004 | 03:37 AM
DroDrizz's Avatar
Question Headlight and Fuel Cleaner
Need some help here guys.......
First, my headlight has gotten a bit foggy on the lens. What would u guys suggest i use to clean the inside of the lens?
And second....... Whats the best Fuel Cleaner to use?
I have a 98' 3.8 Camaro
Old May 7, 2004 | 08:39 PM
JMiller's Avatar
Dunno about the headlight, but dump a can of Seafoam into your tank and you're good to go. (Do a search for Seafoam if you don't know what it is; it's been discussed 8437523580692692 times before )
Old May 14, 2004 | 09:56 AM
kahouna23's Avatar
Your headlight is victim of heat and UV damage. A cheap way to sort of clear it up is to use 3M Polishing compound on the outside of the lens. That should clear it up a "little" bit. Best advice, look on ebay for new headlights. Probably get some for around $50.
Old May 19, 2004 | 05:14 AM
HBHRacing's Avatar
for the headlights, yeah sometimes you can buff them out but replacments are a good idea.
as for the fuel cleaner. Check around some of the local shops and see if any of they carry BG products and get yourself a can of "44K" it;s expensive but it's the best that I have ever used. I ahve used it in my car and countless customer cars
Old May 22, 2004 | 01:51 PM
camarogeek's Avatar
If they're "foggy" as in water vapor condensation than remove them, uplug the drain hole and put them next to your furnace. After a day seal them up and put them back in.
Maybe put a little silicone around the gasket just to make sure its leakproof.
Z28Freak86
Apr 28, 2015 10:35 PM
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
