Head porting
Old Mar 2, 2004 | 09:16 AM
camaros_4_lfe's Avatar
Head porting
Ok i did try searching...
first off i need to know where i can find bits for porting my heads...the summit ones are 1/4" my dremel only does 1/8th and 3/32"
and question #2 i seen a site bout porting heads that was very useful posted here...anyone know what site im talking about?
Old Mar 2, 2004 | 10:37 PM
oil pan 4's Avatar
You will have eo get a 1/4'' die grinder and that is all there is to it.
For head porting ideas to get you started you should just look at lots and lots of pictures.
Old Mar 4, 2004 | 03:38 AM
viper98885's Avatar
Yeah, professional machinists do not use Dremel tools to do their port and polishing. If you invest in the right tools, you will have less hassle in the end.
Old Mar 4, 2004 | 12:27 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
http://www.sa-motorsports.com/diyport.htm
thats probabbly the site you are looking for, also the above is correct, using a dremel to port heads will take FOREVER, trust me, you need a die grinder (air or electric)
Old Mar 4, 2004 | 08:15 PM
yeah thats the site thx
i bought a big die grinder now but the damn chuck only goes to 5/32 so im going to get som modified bits
also i pulled my intake now
and the intake ports in the heads have a big hump in all of them??? what are those humps? can they go?
Old Mar 5, 2004 | 12:31 PM
please if anyone knows what those humps are for let me know if i can grind them down
Old Mar 5, 2004 | 01:36 PM
J0HN D's Avatar
You're talking about where the runners extend that extra 1/4-3/8" up into the plenum?
I had a ported intake that was done by SuperSixMotorSports and he left those extensions up in there.
Old Mar 5, 2004 | 01:42 PM
GordSipko's Avatar
The humps increase air flow in the intake port by 17% over the same port without the hump. The Chevy Power book (available through GM dealers and part outlets) provides a bit of insight. So, yes they can go, but why would you do that? 17% is like dropping 1 cylinder from your engine and you're not going to get it back.
The choice is yours!
Old Mar 5, 2004 | 07:33 PM
atl2001's Avatar
dont remove it... that would make the heads worthless
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Killer94z
Jan 13, 2015 12:06 PM
