Hazard lights coming on and both wheels....
Hey guys i got a 95 3.4L Camaro.. I charged the batterey the other day because it was dead and now it starts fine but every few minutes the hazard lights go on. And i checked the switch for the hazard lights and it is off. What could the problem be, maybe the computer? And also now for some reason when i smoke em up both tires spin and i don't have posi. My driveway was alittle wet but it wasnt that wet where it would cause both tires to spin..Does anyone know what the problem is...Thanks guys
ok umm there is no prob with the tires that is a good thing somtimes if traction is even they will both spin
as for the hazerds turn them on then off and see what happens when they come on tap the switch and if they go of you may need a new one
The steering column they use in the Camaros is ancient...I know they've used it since the redesign in '82 and I've seen it in older trucks. A lot of it is metal, so maybe one of the wires for the flashers has rubbed through and is intermittently making a circuit.
