fog lights
Old May 17, 2003 | 07:35 PM
99huggerorangeZ's Avatar
Question fog lights
i have a 1995 V6 A4(see sig) and my fog lights wont work when i turn on the switch what could be wrong with it???
also i looked in the fuse box but cant find the fuse switch which one is it???
Old May 17, 2003 | 09:22 PM
nothingeined's Avatar
The bulbs could also be burnt out. That is a factory option on those older bulbs. Look on the panel that contains the fuses. It should have a map on what each on is. I'm leaning towards the bulbs being burnt out. When was the last time you changed them out of curiosity?
Old May 17, 2003 | 10:21 PM
i bought the car like 2 months ago and when i drove it off the lot i found like a week later that the fog lamps didnt work
Old May 17, 2003 | 10:40 PM
Yeah. Check the fuse first since that is the easiest. If not....well it's not pretty. Changing the bulbs in the older style is a PITA. But worth it since you get some extra light to help with those sorry foglights.
Old May 17, 2003 | 10:53 PM
There is also a fog lamp relay in the underhood electrical center. Most of the relays are the same, so you can temporarily swap another in to see if it works. You should hear the relay click when you turn on the fog lamps.
Old May 18, 2003 | 06:39 PM
ill turn on the low beams and flip the switch for the fog lamps and nothing happens but ill check the things you listed
Old May 27, 2003 | 01:22 AM
hey guys i removed the fog lamps and found that one bulb was broken and the other was burnt out so i replaced them with 2 new bulbs and the fog lamps work great
Alien
Jun 27, 2015 01:13 PM
PROJECT X
Apr 17, 2015 12:13 AM
Jlo
Feb 3, 2015 09:41 PM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
