faild emissions today
Old Feb 16, 2011 | 10:42 PM
rk_2phat4u's Avatar
Angry faild emissions today
ok my readings were
hc 4.9821 limits are 1.200 fail
co 12.6969 limits are 20.0000 pass
co2 408.5252
nox 0.9143 limits 3.0000 pass
every thing passed but the HC..
so what do you think.. i just replaced the coils, plugs, wires..put lucas injector cleaner in her..
check engine light went off. but failed emmisions.. could it be my fuel filter
or dirty injectors help i just bought her and want to enjoy her
v6 3800
Old Feb 17, 2011 | 11:55 AM
rk_2phat4u's Avatar
Re: faild emissions today
can aany one help me with my maro
Old Feb 17, 2011 | 04:26 PM
transamtom's Avatar
HC is unburned fuel.
I think that your catalytic converter is shot.
You say the check engine light was on?
Did you get the codes read?
How many miles on it?
It could also be the O2 sensors have failed or they are not reading properly.
Sent you a PM.
Old Feb 17, 2011 | 04:57 PM
rk_2phat4u's Avatar
catty converter passed emmisions.... um 165000 miles... i just replaced the 02 the codes i got were left bank 02 evap leak cylinder 6 misfire and egr running at 10%... i replaced 02 cleaned egr tightened gas cap an replaced plugs coils and wires.. now its just a misfire cylinder 6 when i get the car read....
this just started-----> when i rev it in park it starts to cut out at 4000 rpm... it takes a second when i first star it...
i was thinking injectors or and fuel filter
Old Feb 18, 2011 | 06:50 PM
transamtom's Avatar
Your misfire Cyl 6 is probably a bad coil pack,some times you get duds from the parts store.
Old Feb 19, 2011 | 04:09 PM
rk_2phat4u's Avatar
ok i will look int it thanks
but i does pass the spark test
Old Feb 19, 2011 | 07:07 PM
transamtom's Avatar
For voltage or visual spark?
It could still have visual but not be strong enough to fire the plug.
Old Feb 19, 2011 | 09:11 PM
rk_2phat4u's Avatar
yea just to the eye.... but if it was a coil wouldnt i have multiple misfires???
i seafoamed her too and there seems to be a difference but still hesitates when first strarted... i put bg fuel injector cleaner in her as well... so when that tank is on E im going to put the new fuel filter on then maby see whats up....
Old Feb 20, 2011 | 12:10 PM
transamtom's Avatar
Coil packs are cheap and usually the culprit,make sure you use the new seal it comes with.
Old Feb 22, 2011 | 11:13 PM
rk_2phat4u's Avatar
ok yeah i didnt use those i will have to put those on... yeah the old ones looked good....
Formula Steve
Sep 19, 2023 08:31 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RX Speed Works
Jul 24, 2015 02:25 PM
