experts help im stumped?
Old Oct 27, 2006 | 09:15 PM
diabeticfirebird's Avatar
Angry experts help im stumped?
ok so yesterday my car ran perfect and todayit seized upno warning nothing WTF? ......oil perfect level ,,no leaks....just had headgaskets changed. engine has 103000 miles on it but im stumped it gave no warning just bam run like **** then seized up
Old Oct 27, 2006 | 10:42 PM
3800FBL's Avatar
Hydro locked? It has been raining alot lately.. but we'd need more info. Can you turn the crank by hand? If not, do you hear any clanks or noise? What noises/actions did it make before it locked? Sure the timing chain did'nt just break on you? Any visible block damage?
Old Oct 28, 2006 | 02:20 PM
nope crank frozen what exactly is hydro locked? engine was just serviced block is great no leaks
Old Oct 29, 2006 | 11:17 AM
oil pan 4's Avatar
I have seen only once, the oil pick up fell of an oil pump on a GMC truck once.
Engine was done.
And on a motor cycle the pick up oil pic up screen got cloged by RTV sealant and it just ran worse and worse and before to long engine was toast.
I have also heard of plenty of engines being ruined by the oil pump loseing is prime with brand new engines or engines that have been sitting a long time. And they don't die right away.
There are just so many things that can do an engine.
Old Oct 29, 2006 | 11:24 AM
s
the fuunny part is this all happened in 30 mins just all ofa sudden it started acting wierd making noises then whil iwas letting it idle it froze up. tech guy couldnt even crankm it by hand......if anyone knows were i can get a cheap 3.8 engine and trans id be appreciative
Old Oct 29, 2006 | 12:19 PM
b.lee's Avatar
why do you need a trans?
Old Oct 29, 2006 | 12:35 PM
it was starting togo
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Xiantyl
Jul 21, 2015 05:42 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
