dies after 10 min.
Old May 18, 2010 | 03:06 AM
af gibson's Avatar
dies after 10 min.
i have a 1994 3.4 camaro that dies after running about 10 mins. tried new module, new crank sensor, cam sensor, coils,still dies tried a junkyard ecm no change have no computer response at aldc but have a hard check engine light some one has replaced ignition switch but took old switch and put the key in it and tied it under dash desperate anyone have any ideas also oil pressure gauge stopped working
Old May 18, 2010 | 09:07 AM
byrons1502's Avatar
does it have spark after it dies. check for spark cranking. then spray a little starting fluid in the throttle body to see if it will run for a second then die. that will tell you if it is fuel related(or injectors). do this and repost.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
