did a compression check - got questions
Old May 31, 2004 | 08:45 PM
95camaro3400's Avatar
my 95 3.4 has 145k and i just did a compression check, and it came back with the following:
#1-200 psi
#2-205
#3-190
#4-170
#5-190
#6-210
my question is: are these good numbers , i plan on rebuilding so should i look into high compression pistons or would the gains not be worth the $$? and if these numbers are low what kinda compression should i be looking at after a rebuild (honing re-ring pistons, etc), basically im gettin my engine ready to do some n/a work (cam ,p&p, etc) any info such as what cam to get or anything else will be appreciated
thx
Old Jun 1, 2004 | 08:08 AM
oil pan 4's Avatar
Not the best, they should be within 25psi of each other.
Get a crane flat tap mechanical cam for. search you will find it.
You sould see no less than 205 on all cylinders after the rebuild.
ChrisFrez
Dec 28, 2014 02:25 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
