Basic v6 upgrades....????
Old Nov 27, 2002 | 04:34 PM
CADEman98's Avatar
im really looking into getting these things for xmas
springs
whisper lid
filter
some custom v6 decals
what springs should i get, i really would like a 2 inch drop, no mo' no less, where to find, who to buy from, how much..etc etc etc.......where should i get the whisper lid???....
and finally,,, what exhaust gives the best bang for the buck on 3.8 ltrs?
thanks guys
Old Nov 27, 2002 | 07:24 PM
ibanez6rg's Avatar
I would go with Eibach springs.
I would also go with Flowmaster or a Dynomax cat-back exhaust.
Various site you can check out are www.suncoastcreations.com www.ftforce.com www.ebay.com www.driverfx.com www.hawksthirdgenparts.com
Old Nov 27, 2002 | 11:03 PM
1fastV6's Avatar
or better yet http://thunderracing.com http://slponline.com for your lid
http://reflectiveconcepts.com for your decals or http://firebatscave.com
and i would go with a regular flowmaster 80 series. i truly believe thats the best bang for your buck.
for the springs, eibach if you have money or H&R if you dont.
Old Nov 27, 2002 | 11:19 PM
CADEman98's Avatar
but i did not see a place where i could get a 2 inch drop...i know they are out there, i found a couple a few months ago......
YO NECESITO!!!
thanks so far, good sites....
Old Nov 27, 2002 | 11:24 PM
1fastV6's Avatar
btw its thunderracing now
and a 2 inch drop might be hard to find. have you tried suspension techniques? or maybe even some coilovers? do they have those for our cars??
Old Nov 27, 2002 | 11:31 PM
ibanez6rg's Avatar
http://www.suncoastcreations.com/miv...ory_Code=CAT4E
All you had to do is a little searching within the links I gave you
Go to "Select Drop Rate:" and click "1.75-2.00"
CADEman98's Avatar
i dont want coilovers...they ruin your handling, right? And i could have sworn that eibach made a set that droped it 2 inches.....i need good handling shiat too.....
and what do you think...whisper lid or cold air???
Old Nov 27, 2002 | 11:34 PM
CADEman98's Avatar
well ill be a monkeys uncle.....but look at that price!!!! dizzammm
so whisper lid or cold air....hmmmm decisions decisions
and those eibach will be like hella good handling huh...
1fastV6's Avatar
both!
but if you have to do one first- lid then cai
you will really appreciate the lid. very noticable and a five minute instal at that
Old Nov 27, 2002 | 11:40 PM
CADEman98's Avatar
how do you do "both"? at the same time, all the pictures i see suggest they wont be compatible....?
Old Nov 28, 2002 | 12:09 AM
codyman16's Avatar
They are both compatible, as long as you have a 98 or newer f-body which I assume you do since you are looking into a whisper lid. Also you can get a better air filter like k&n to make your induction even more complete. Also i would recomend taking off your air silencer and getting a flexible intake hose in its place if don't get the whiper lid( I think the whisper lid does this also) It makes your car sound better and gives it some more power.
Old Nov 28, 2002 | 12:20 AM
CADEman98's Avatar
some one explain how they will both work if they both must go into the same slot, but there is only 1, and there are 2 things. Im confused
Old Nov 28, 2002 | 12:47 AM
shortdog273's Avatar
It's the ram air kit they're referring to as the CAI. Fasttoys, SLP and Whisper are the main companies that makes them. Tbyrne sells both the lid and ram air kit. As far as springs, I went with sprint springs. It dropped my car 2+ inches all around.
Old Nov 28, 2002 | 06:24 PM
1fastV6's Avatar
both!
the airlid goes on top- what you see when you pop the hood. the cold air induction goes underneath the lid- you will be able to see it behind the radiator from underneath the car only. its really simple. for the cold air induction you will have to cut some plastic on your car for it to fit and it falls right into place.
Old Nov 29, 2002 | 12:19 AM
chesee48's Avatar
get them both!
