Another Issue with the 3.4
Hey guys I have a 3.4 95 5spd and I have had my fair share of issues with it. I have put a new icm, ngk plugs, ac delco wires, tps, iac valve, and replaced all the ignition coils. Also I have put in a new clutch. The car has been running like crap the last few weeks after changing the plugs and wires the car is still smelling like fuel really bad. The only other thing I can think of is the fuel injectors are bad any thoughts would be greatly appreciated
Here is my original post
95 3.4 ticking noises
I have a 95 3.4 camaro and the other day I went for a drive about 100 miles round trip. About 5 miles from home the car started making a slight ticking sound and my oil pressure dropped from 40psi to about 20psi. I was about 300 miles from needing an oil change but changed the oil anyway to see if that would help but it didn't. A friend said it could be anything from an exhaust leak at the manifold all the way to needing a rebuild any ideas would be greatly appreciated.
Re: Another Issue with the 3.4
I guess the v6 part of the site dont get a lot of traffic but I've figured out the problem. It started when I was getting a ticking sound come to fing out it was nothin with the motor it was #3 coil arching so i had that changed next came the plugs and wires and still miss fire /ticking noise so I changed the other 2 coils and still nothing then onto the icm nothing I went to a mechanic friend and we swapped out the first coil i had a shop change and the car runs fine now all is well that ends ok because the parts were probably due to be change anyway
SpeedJunkee
Jun 6, 2015 04:27 PM
Latronaxe
Apr 29, 2015 08:25 AM
