95 v6 3.4 mileage problems
Old Mar 7, 2012 | 12:38 PM
eithacos's Avatar
i picked up a v6 3.4 with a gutted cat the gas mileage is terrible (somewhere between 10-15 mpg) i took it to a muffler shop and i was told that the o2 sensor was getting a false reading because the cat was gutted is this true and what can i do to test/fix it? i get a ses light on the highway as soon as i let off the gas but for some reason he couldnt get a reading from the computer any help or ideas is much appreciated
Old Mar 12, 2012 | 11:21 PM
Sinister-Z's Avatar
Re: 95 v6 3.4 mileage problems
Is the O2 sensor behind the cat? If not then the O2 shouldn't throw any codes. I would start with a good tune up (plugs, wires, filters) and see where your at.
Old Mar 13, 2012 | 04:27 PM
sick94's Avatar
The O2 sensor on a 3.4L is before the cat so that should not be your problem. Check plugs, wires, coils, fuel filter, egr valve, pvc valve, air filter, etc.
Old Mar 18, 2012 | 02:28 AM
ImportKILLER's Avatar
Pre-cat: will affect MPGs
Post-cat: won't affect MPGs, simply checks cat efficiency.
o2s are cheap enough, replace it and see if it helps. Won't hurt having a fresh o2 on there.
SpeedJunkee
Apr 23, 2015 09:51 AM
HectorM52
Jan 30, 2015 11:08 PM
Jason Short
Jan 19, 2015 06:34 PM
Dec 1, 2014 08:08 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
