94 retiming
Re: 94 retiming
The only way you could do that is if you misaligned the timing chain, or somehow installed the crank and/or cam position sensor incorrectly. Are you sure you have the spark plug wires installed on the correct coil/cylinders? Valve lash set correctly?
Re: 94 retiming
When i replaced the gaskets i took the heads apart to clean them up and mistightened to rocker arm nuts. i need to get them properly tightened and would rather a pro do it than continuing to adjust them myself and possibly making the problem worse
Re: 94 retiming
Then it's not a valve timing problem, it's an adjustment problem. I suspect a shop would charge you 2 hours of labor to adjust them..... $150 - 200 depending on you local rates. Maybe less than 2 hours if they are honest.
GSS9909
49
Jan 14, 2009 10:54 AM
SunsetHawkSelena
13
Nov 12, 2008 02:57 PM
pv2hodge68x
May 27, 2008 10:58 PM
