3.4L guys need help oil problem with my car...
Old Jan 10, 2003 | 04:01 PM
MustangEater82's Avatar
Well....
My car was leaking oil severely bad, about a month ago I noticed my oil filter was splattere with oil while getting an exhasut system installed, guy's opnion is the filter is leaking. Car wasn't driven too much, but now is I have been putting off but checking the oil very consistently, and it was slowly getting worse, at one point lost half a quart in a day. Got a drain plug I was needed, and was took awhile to find(was waiting till i got this to change oil/filter)
last night I flush the motor, change oil, filter, and draing plug.
When I took was under the car, I noticed oil, fell on my y-pipe, and leaked its way all the way over to my CAT. I took the filter off nothing apparently wrong with it, maybe the seal was bad?
i look around at where the oil filter connects nothing apparent but then again, its not an easy spot to get a view of.
I put new filter, on, new plug, fill up and drive. I am loosing some oil, but haven't been able to keep track of it, since I jsut swaped it last night, any ideas what it could be?
there ws something sticking out of the part where the oil filter connects, i am assuming the oil pressure sending unit, looked kinda like a big boot was over it.
How does it work, does it jsut stick in and test oil pressure, or does oil actually flow up inside of it? It had oil on it but if the seal was leaking on the filter, most likely would get oil all over the sending unit.
Any idea what could cause this, I thought possible valve cover, but I think its highly unlikely.
also anyone know if the part that the oil fitler connects to is known to fail?
Thanks in advance, I think I might cancel my plans to go autocrossing, I know if i keep oil in the cr it will be fine, jsut don't think pushing the car 2 hour round trip, and autocrossing is a good idean and I hate when people drip oil on the track.
Old Jan 10, 2003 | 11:41 PM
94GrayV6's Avatar
I had a problem similar to what yours is, my car would leak oil all over the y pipe and as a result would smoke like hell. What it was is that the part that the oil filter connects to was cracked. I'm not sure what it's called, but its fairly inexpensive to fix if i remember correctly. Can you see precisely where the oil is coming from?
Old Jan 11, 2003 | 12:34 AM
I was thinking about that, I am very happy you imed me that it only cost oyu ~$50-60 at a dealer to get fixed.
I picked up a sending unit Ia dm ogng to try and swap that tomorrow, I think this is what it might be I found alot of oil in the boot, that goes over the sending unit.
Old Jan 11, 2003 | 01:27 AM
southern94's Avatar
i doubt its the sending unit only way it would leak is if it was snapped off and you would see that clearly and when it is snapped off it don't leak that bad i know i snapped mine putting on my headers but i also had problemes with the oil filter bracket that bolts to the block my guess is thats your probleme cause mine leaked the same way it could have been hit hard by a person not paying attention it's only held on by one big center bolt which oil actually flows through so i would check that
Old Jan 11, 2003 | 03:16 AM
badasscamaro's Avatar
This probably wont help and probably just talkin out my *** but,
when you changed your oil did you rub oil around the seal on the new filter if not sometimes it will crack and leak but not that bad how you described.just throwin possibilities out there.good luck
Old Jan 11, 2003 | 04:05 PM
94GrayV6's Avatar
WOW! That was one hell of a run-on sentence! Southern, please throw in some punctuation and capitals on occasion to ease the eyes of my fellow board members and I.
But I think you're right though regarding the oil problem.
HectorM52
Jul 30, 2017 11:46 AM
artic94
Jan 17, 2015 11:19 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Red97LT1
Aug 7, 2002 05:45 PM
