Is the 3.4 this much of a dog ?
Old Oct 7, 2010 | 07:38 PM
transAMdriv3r's Avatar
Ive been slowly trying to get this 95 camaro m5 back road legal after it was wrecked in the rear quarter panel to sell it and make a quick buck.
I had replaced the plugs and wires, all the fluids you know... the basic tune up stuff except fuel filter. The plugs were autolites I believe and the wires are accel "built your set" wires...
Maybe its just because I'm used to the Lt1, but this thing doesn't seem to have any kick what so ever. Its not missing or anything and it has a new cat, but even going up hills it seems asthmatic and I have to keep down shifting till I'm about 3k rpms to make it up without losing speed.
I had a guy come test drive it to buy and even he said it doesnt seem to have any kick to it and was comparing it to his van which "has *****"
He was suggesting it was something vacuum related but I sprayed carb cleaner around and couldnt find anything.
Old Oct 8, 2010 | 12:27 AM
95camaroinok's Avatar
Change the fuel filter, add a bottle of your preference of injector cleaner, try AC Rapidfire plugs and some basic autozone/orielly/whatever parts store wires, air filter, pcv valve. Unless its a mechanical issue/ bad gasket somewhere, that should get it in good shape. My 3.4 has about 170,000 on it and screams for a 6. No problems melting tires, no problem hitting the speed limiter. They like rapidfire plugs. Is the check engine light on?
Old Oct 8, 2010 | 08:46 AM
sasquatch152's Avatar
One reason the 3.4 doesnt get much power is because it is designed badly, it doesnt get much airflow throughout the engine so it cant get much power
Old Oct 8, 2010 | 08:50 AM
no no engine light, never have to add any coolant and oil is always clean. oil pressure is around 70 cold and 30 warm idle. it just seems like it cant breathe or something, I dont even think it can do a burnout.
Old Oct 9, 2010 | 04:42 PM
Okay I just went ahead and started replacing sensors that I got from a salvage yard...and it worked !!!!!!! pretty ballzy now for a 3.4 hehe
Old Nov 6, 2010 | 12:10 PM
frigason's Avatar
Re: Is the 3.4 this much of a dog ?
which sensors did u replace?
Old Nov 17, 2010 | 08:44 PM
I replaced the map sensor, tps and Idle air control...I was at a junkyard and found the new sensors and thought I might as well try them...Im thinking the one that fixed it was the map maybe the tps too
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
SpeedJunkee
Jun 6, 2015 04:27 PM
Latronaxe
Apr 29, 2015 08:25 AM
