3.4 info?
Old Dec 12, 2002 | 11:57 AM
94TeALFiReBiRd's Avatar
Exclamation 3.4 info?
give me as much stock info as possible.... 1/4 0-60 etc..... engine things compression stock cam everything possible about the 3.4
Old Dec 12, 2002 | 02:18 PM
ibanez6rg's Avatar
drivetrain/front engine, rear-wheel drive
engine code/L32
compression ratio/9.0:1
displacement(liters,c.i.d.)/3.4L, 207
hp-rpm/160 @ 4600
torque-rpm/200 @ 3600
fuel induction/SFI (sequential fuel injection)
fuel injectors/24lb
Old Dec 12, 2002 | 05:32 PM
Tiago's Avatar
the injecctors are 17lb!
Old Dec 12, 2002 | 07:53 PM
Ve/\/om's Avatar
The 3.4 DOHC is better!!! I know...mid 15's vs. high 17's
Old Dec 12, 2002 | 08:13 PM
ibanez6rg's Avatar
You sure??
Old Dec 12, 2002 | 08:26 PM
V6 Punk 93's Avatar
High 17's? Maybe a few poorly tuned 3.4's are running high 17's but most of them I see are running mid-high 16's.
Old Dec 12, 2002 | 09:43 PM
94GrayV6's Avatar
This should help... http://engine.firebirdv6.com/
Oh yeah typical stock acceleration times are 0-60 in 9ish and 1/4 in the high 16s.
Old Dec 13, 2002 | 12:47 PM
Ve/\/om's Avatar
http://wp.netscape.com/fishcam/fishcam.html
Old Dec 13, 2002 | 01:22 PM
MustangEater82's Avatar
the dohc 3.4L is very unreliable, likes to eat alternators, break timing chains, and a huge long list.... Very expensive to maintain.
THe 3.4L has cast aluminum pistons.... which is a downfall when it comes to severely tuning it.
3.4L are typically high 16s..
and hey my 3.4L is mid 15s
Old Dec 13, 2002 | 01:31 PM
yea i know someone with a 3.4 lumina z34 always messes up.......
Old Dec 13, 2002 | 01:59 PM
All_InTheRED's Avatar
And some very well maintained ones that run 17.8.
.......and I have seen others do the same at the same track.
Old Dec 13, 2002 | 07:03 PM
fbird95's Avatar
the dohc 3.4 Certainly does go along with the general scheme of grand am engines being unreliable.
Old Dec 14, 2002 | 12:10 AM
yea so true they suck!!!!
Old Dec 16, 2002 | 11:14 AM
Ve/\/om's Avatar
Unreliable? Not really if well maintained....and there timing belt engines. ALL dohc 3.4's are forged aluminum rods/pistons.
blac94Z
Nov 4, 2015 01:59 PM
colts0455
Oct 4, 2015 09:47 PM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:21 PM
CARiD
Sep 7, 2015 08:21 AM
