1995 camaro no start
Old Mar 11, 2009 | 12:07 AM
antoine's Avatar
my friend has a 1995 camaro 3.8 v6 i put a fuel guage on it because he said it will not start,it had zero fuel pressure so we put a pump in it and still no start or fuel pressure but if we jump the relay by the driver side kick panel the
pump will prime but still no start its getting spark.i put my scanner on it so i could command the fuel pump relay but it is saying can't communicate with module did the ecm burn out .
Old Mar 23, 2009 | 10:53 PM
Dave_A's Avatar
Unless you have the GM scanner (or a few other select models) you aren't going to be able to connect to the 95...
Been there, tried that, the system is some weird franken-hybrid of OBDI and OBDII
Old Mar 24, 2009 | 03:59 AM
BlackBird97's Avatar
Have you checked the fuse for the fuel pump?
Old Mar 24, 2009 | 03:17 PM
antoine's Avatar
fuel pump fuse is good
Old Mar 24, 2009 | 03:30 PM
Dave_A's Avatar
Does it run (briefly) if you spray staring fluid up the intake?
calaban
May 18, 2020 06:43 PM
joe777107
Dec 1, 2014 09:32 AM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
Chrisdude
Jul 24, 2002 02:25 PM
