1990 Firebird....engine cranks, but wont start! HELP!
Old Apr 30, 2004 | 11:20 PM
ImportKillerZ28's Avatar
I have a 1990 Firebird-V6. My engine cranks over but im getting no spark to the spark plugs at all. Might it be the coil? I put brand new rotors, caps, plugs, wires, distrubutor, and brand new module with the dist.....there's a spark from the coil to the cap, but none from the cap to the spark plugs........any thoughts???
Old Apr 30, 2004 | 11:52 PM
Javelin3o4's Avatar
how did you check for spark to the plugs did you use an old plug in a sparkplug wire or tester? also when you changed the ignition module did you remember to plug the little wire into the module thats under the distributor (not the 2 external plugs).
Old May 2, 2004 | 05:33 PM
I used an old spark plug...everything was connected also....?? any more ideas?
mackirockz
Feb 4, 2015 07:03 AM
Jessie4tin
Jan 7, 2015 08:53 AM
