what will my friends 99 Z really run?
ok, i have a mustang and my buddy has a 99 Z. he is FINALLY modding his car after about 6 years! he is getting full exhaust with headers, the cold air intake box thing (?), and short throw shifter. what do you think he will consistantly run in the 1/4 with regular tires? thanks,
jim
this is not a "mustang v camaro" post, im just curios as to what his will run with the aforementioned mods.
my best is 12.8 at 111 mph.
jim
Re: what will my friends 99 Z really run?
I'd look for some consistent low, low 13's, depending on his traction situation and where you are located (elevation). That is what I see at Indianapolis Raceway Park here in Indiana. Most LS1's I see here are only running a street radial and usually get 2.1 60's and net mid to low 13's with an intake and a catback. If he had some slicks and wanted to give that 10 bolt some hell he could see 12's easily
BTW, is he getting longtubes?
Aaron
Aaron
If it helps a kid around here has a Trans Am with the same mods and he raced a Mach 1 running 12.8's. In the words of the Mach1 guy, "he murdered me" The Mach got the jump but the TA went flying by, from what I understand. Hope that helps.
-Dustin-
-Dustin-
-Dustin-
-Dustin-
Aaron
thanks, i thought it would be around there. sounds like low 13's with good traction. how much HP is that gain for the camaro? I am not sure if they are long tubes or not, but exhausts compared to mustangs are pretty expensive. i think he wsa running high 13's stock. we live in new york, upstate. he may be disapointed if he can't hit 12's, he was talking as if he would easily hit 12's, but i didnt think he would be able to without DR's.
thanks,
jim
thanks,
jim
should be interesting to see. people who think high 12's would be droppping close to a full second off his time! that would be impressive with only those mods. he decided not to get gears, even though i thought he should get them, but oh well!
Most LT1/LS1's repsond well to full exhausts and intake work. Its not uncommon to drop a second from your time. I expect to drop more than that from the few bolt on's I have. Biggest mod he's going to need it DR's to compete.
-Dustin-
-Dustin-
well, we made it to the track. his best time was 13.2 @ 105 with a 2.0 60' time. mostly he ran 13.3's and 4's. thanks for info. he is alittle disapointed but i guess this is what they really run around here as there were 2 others with similar mods and similar times.
thanks,
jim
thanks,
jim
last time at the track there was a 99z with shortys' and dr's, pretty much stock everything else. He was running 12.8-9 @ 109 with m6
My best time is in sig with 99 a4 z
