Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
The new Vig is in... and she's AMAZING...
Old Mar 7, 2009 | 08:58 PM
  #16
canuck94z28's Avatar
Originally Posted by OVA1
Oh HELL YES!
Can't even THINK about runnin' a stall without a tranny cooler.
I don't recall the manufacturer... but as a general rule the bigger the better.
I'm just bought a finned oversize tranny pan, hopefully we'll get it installed this week end... it adds 2 quarts of fluid in volume and the fins heat-sinks the pan providing great surface area for air to pass over to promote cooling.
You're going to LOVE the Vig man... best money you've ever spent on that car.
I ,m looking at one w/a gvw of at least 1900 and considering the gains i got from first the 1.6 rockers,then the headers,things are getting real good now,but i can,t wait till that Vig is in & the c/o.Thanks for that info.
Old Mar 8, 2009 | 10:33 PM
  #17
marshall93z's Avatar
Oh HELL YES!
I have a 3600 without a cooler. I wouldn't advise running around with it unlocked either, though!
Old Mar 28, 2009 | 08:28 AM
  #18
Kraest's Avatar
Retired
Originally Posted by wyldcdn
I'll back it up..i installed a 2800 in mine
dropped my 60's from mid 1.9's to 1.73. Everything else he said is the same its flat out nasty out of the hole. One question. Any problems with gear changes on the track? or did you get a tune? At the track mine would bounce off the rev limiter on 1st to second. Street it never does it. Mines a 9 1/2 also
The OBD1 cars have problems when you put 2800+ stalls in them.. has to do with the VSS not being in sync with the car's speed vs. RPMs of what it thinks it should be.. it really shows on the track because the car is fully loaded up with full traction and the converter is stretched out. I had a 2-3 problem on mine, but we're talking about 7-8 years ago when I still had an LT1.
Best bet is to get it tuned or convert to OBD2. I had my transmission built and converted to an on/off switch with the computer and the ability to fully change the gears as I pushed them up from 1 to D... I could actually take off in 3rd if I wanted to. That fixed the problem, but the other problem after I put the 396 in was melting the 4L60E.
Old Mar 29, 2009 | 11:45 PM
  #19
94+ OBD1 cars.
Old Mar 30, 2009 | 01:07 AM
  #20
bombebomb's Avatar
How much of an issue is this going to be with say a 3500~ stall, I do not want to be bouncing the limiter , tons of others have done it so I am sure I will live.
Old Mar 30, 2009 | 07:05 AM
  #21
Kraest's Avatar
Retired
I think by now (15 years since the 1994 cars ROFL! ), the problem should have been fixed/address, so it shouldn't be much of an issue anymore as long as you get a tune from a reputable tuner, a tranny cooler, and a shift kit.
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Bird of death
Nov 2, 2002 08:31 AM
TEAL94Z28
Oct 8, 2002 11:06 AM
CaptainHam
Jul 9, 2002 06:28 PM
