LT1 Z28 stomps procharged Cobra
I finally got a chance to run a friends' Cobra the other night.
Not sure what year it is: 4.6-32 valve. He added a Procharger, longtube headers, full exhaust, and methanol injection. I think he's running 12 pounds boost.
1st run was on 3 honks from a 30 roll. I LEFT him by about 4 cars and stayed there 'till I let off in the top of 4th.
2nd run, again from a 30 roll, I started from 3rd and let him go. He jumped out 'till his door was at my fender. I started coming back and when he shifted to 3rd I put about 3 cars on him, and kept pulling 'till I let off in the top of
4th. WAY to fast for the street, but I didn't want any B.S. about not giving him a chance to catch up.
He complained about traction issues, and still claims to have the faster car "if I could hook up". If that 'stang is as bad as he thinks it is, why wasn't he reeling me in after he hooked up?
Whatever, N/A bowtie power(and BMR chassis mods) got it done the way I see it.
Mod list:
396, Eagle forged crank(3.875") 6.125" rods, diamond pistons(4.030").
CNC ported stock heads by ETheads - 2.00"INT/1.55"EX valves.
Stock LT1 manifold except for the 58mm TB.
CamMotion custom grind, 234.5/.575"INT-241.6/.598"EX on a 112.
Morel lifters, 1.6 pro mags.
Stock opti, MSD blaster and 6AL, Magnacore 8.5mm wires.
Jet-Hot longtubes and ORY pipe to a Magnaflow cat-back.
K+N CAI.
Spec stage3, stock flywheel and stock T-56 w/B+M ripper
Strange 12 bolt, eaton posi, 4:10 gears.
BMR chassis mods: SFC's, LCA's, upper and adj. lower panhard bars, front and rear sway bars, torque arm, and trans mount crossmember to re-locate the TA to the crossmember.
275-17" Nitto 555R fronts, 315-17" Nitto 555 DR's on ZR1's.
K+N CAI.
You have nearly the same setup I have on my 97 thats sitting in the garage right now. I have converted it to a pure drag car and it has a turbo 400 auto.
I can see you putting a hurtin on him. A properly put together and tuned 396 can be a 10 second runner all day long.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
