Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
LS1 Dodge Ram vs. LT1 Camaro
Old Sep 8, 2010 | 10:23 AM
silverz28camaro's Avatar
http://www.youtube.com/watch?v=pCokG...eature=related
http://www.youtube.com/watch?v=Fryki...eature=related
Old Sep 8, 2010 | 10:28 AM
LT1 ran a 14.45 @ 95 2.10 60' all stock auto. 3,700 lbs
Ls1 has headers, custom intake, 3.90 gears, 31 in mudd tires, and 4,400lbs
Old Sep 8, 2010 | 08:51 PM
John M's Avatar
Well I'll be damned - you really can put an LSx into anything!
Old Sep 8, 2010 | 10:19 PM
henryz28's Avatar
That truck sounds like it has a upgraded cam.
Old Sep 9, 2010 | 07:38 AM
razor02097's Avatar
In other words...... Stock lt1 vs highly modified ls1 put in a old truck
Old Sep 9, 2010 | 09:57 PM
LOL, nope thats just the way a good running motor sounds, its a completely stock LS1 longblock,stock cam, stock heades, staock manifold. Only mods were some used ebay headers from a camaro and a o'reileys spectre brand air filter.
You must keep in mind I'm racing an LT1.......
Old Sep 9, 2010 | 10:00 PM
Headers = highly modified?
Seriously the ls1 is untouched, in the video of me revving it up it has open headers...right after I got the wiring done... Now with mufflers and new plugs it idles at 600rpms and smooth like it should.
The motor is a 98 LS1 and is the early style with perimeter bolt valve covers. Heads do not flow near as well as the later ls1 heads
Old Sep 10, 2010 | 07:12 AM
razor02097's Avatar
I read the replies too fast I though you said it had an upgraded cam
now that you made the conversion when is the stroker LS2 going in?
Old Sep 10, 2010 | 06:27 PM
Most likely will not stroke this engine , I do plan to finish the bolt-ons and see where that gets me I found a good deal on a ls6 manifold..$100 and also I would like a underdrive pulley.
I mainly want this truck to be a daily driver with the ability to run mid-high 13's
I'm going to the track next friday to see where its at now.
Old Sep 13, 2010 | 09:21 PM
8cylinders>4's Avatar
wow that lt1 is a dog!
Old Sep 15, 2010 | 07:55 PM
henryz28's Avatar
That's what I here; the open headers and it sounded a little off. I bet it sounds much improved with the new plugs and mufflers on. A lt1 should have killed you from a stop though, I have seen many stock ls1 fbody's vs stock lt1 fbody's and the lt1 pulls ahead in the start then the ls1 usually wins in the end. What trans and rear gears are you running in the truck. That is a fast truck any way you look at it though. I would like to see you run a new dodge ram 5.7
Old Sep 15, 2010 | 08:09 PM
Antz97ZNJ's Avatar
Damn those pds are making the LS1 look bad
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Nov 23, 2014 10:33 AM
