Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
car to slow, got beat by a SS
Old Aug 1, 2007 | 08:00 AM
  #16
teke184's Avatar
"I think when I hit 4th gear It would have been all over, but he swears he was only in 3rd playin with me."
sounds like you were in your dead spot on the auto.
and as jake said...100+ is very possible in 3rd gear...and quite honestly...if you had raced higher it would have been uglier.
4th gear is a fun gear for an LS1
overdrive in an auto compared to 1:1 in the m6....i don't think "it would have been all over"...unless it was the other guy winning
Old Aug 1, 2007 | 12:54 PM
  #17
LSWHO's Avatar
Originally Posted by DonutMachine
how bout this ? should i get now or wait
Patriot Ported heads
New in the box. CNC ported with thier upgraded springs. 2.08/160 valves. Flow over 300 at .600 lift. I checked and they will fit an LS1. 243 castings
$850 or best offer...
__________________
Don't you have an LT1? These won't work for your car.
Old Aug 1, 2007 | 12:56 PM
  #18
JakeRobb's Avatar
Super Moderator
His sig says he has a '98 Z28. That's an LS1.
Old Aug 1, 2007 | 12:57 PM
  #19
LSWHO's Avatar
holy crap
Old Aug 1, 2007 | 12:58 PM
  #20
LSWHO's Avatar
really cause i beat gto's, chargers, I can't tell the differeance between the c6 and the c5, they look the same to me(i think lights). I have never lost to a stick car from a dead stop in my LT1(93). He took me from a roll, acutally we both turned left and my attempt to pass him failed. Does your exhaust give you guys a definitve advantage, also ls6 intake right? never mind i'll search
I went off this post. Never read his sig.
Old Aug 1, 2007 | 12:59 PM
  #21
JakeRobb's Avatar
Super Moderator
holy crap
Old Aug 1, 2007 | 03:13 PM
  #22
DonutMachine's Avatar
sold my lt1 or lost it R.I.P.. I set my rev limiter to 6500. I put my own rear end on It came out a 6 speed. I think i just hit my dead spot in 3rd gear. FYI, I just picked up a fiberglass SS hood, big differance. I beat a new gto yesterday on the freeway, he was right behind me, but man those sound so bad a$$ compared to my car even though i have a loudmouth. They sound like the have more low end torque and grunt
Old Aug 2, 2007 | 04:10 PM
  #23
00Z28SS's Avatar
Thats an awesome deal for those heads. Almost too good to be true. Like said before though, you should do the supporting mods first.
Old Aug 2, 2007 | 05:13 PM
  #24
this board has taught me a lot, hell if it weren't this forum I might be driving a honda or something. I am really dumb when it comes to heads and valvetrains numbers and stuff. I just want a really fast car, not a quick or sort of fast car
Old Aug 2, 2007 | 05:14 PM
  #25
supporting mods such as, I need headers, torque converter and some subframe connectors
Old Aug 4, 2007 | 12:51 PM
  #26
dbmason's Avatar
Originally Posted by JakeRobb
Assuming everything in your car is stock:
Rev limiter: 6200 rpm
3rd gear ratio: 1.30:1
Rear end ratio: 3.42:1
Tire size: 275/40ZR17
A 275/40ZR17 tire is 25.661" tall. Multiply by pi to get circumference -- 80.618".
6200 / 1.30 = 4769.231 rpm at the driveshaft
4769 / 3.42 = 1394.512 rpm at the axles
1394.512 * 80.618 = 112422 inches/minute
112422 inches per minute is 106.461 miles per hour. If you shift at 6000, you'll be doing 103 mph.
Either you're shifting into 4th at 5000 rpm, or a previous owner installed 4.10 gears and didn't pass that information on.
thanks for the specs, thats stuff i didn't know. the car is stock as far as i know with the slp options listed in my signature
Old Aug 10, 2007 | 06:04 PM
  #27
1LE4ME's Avatar
Originally Posted by dbmason
I highly doubt you are going to be an SS with an A4, I've got an 2001 SS (M6) and other SS's cant beat me, so good luck with that. What kind of street were you on? in town? or what? cause I can do 85 in 3rd, so if you were in town, he proly was just playin with ya.
You can only do 85 in third? I cross the traps at 100+ in third, maybe I've got different gearing, M6 here also.
Old Aug 10, 2007 | 08:35 PM
  #28
JakeRobb's Avatar
Super Moderator
I'll bet you $50 that you have aftermarket 4.10:1 gears.
Old Aug 30, 2007 | 08:46 AM
  #29
dbmason's Avatar
I tend not to shift as high as some, i shift between 5,000 and 5,500 or so, unless i'm racing at the strip, but there i never see the end of 3rd, i barely see the end of 2nd
Old Aug 30, 2007 | 08:48 AM
  #30
JakeRobb's Avatar
Super Moderator
That'd be an eighth-mile track, wouldn't it?
I cross the quarter-mile traps in 4th.
