Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
04 gt vs 85 iroc
Old Sep 2, 2008 | 10:52 AM
chevynutman's Avatar
04 gt vs 85 iroc
went to the NE dragway last friday
only got in three runs due to they had king of the hill running at the same time
found how bad my new tranny is after second gear
took him off the line
had him at 60'
had him at 100'
got to 330' and he had .4 on me
and by the time we hit 1/4 mi he took me by a full second
he was at 96mph and i was at 88mph
between my tranny not shifting until 4800rpm and it kicking down to second while trying to go faster(any more than 3/4 throttle)----------------------
I THINK I NEED A BETTER TRANNY
Old Sep 2, 2008 | 07:47 PM
MauriSSio's Avatar
im sorry i dont fully understand, but not shifting UNTIL 4800rpm? i know the TPI's long runners kill RPMs but is 4800rpm still to fast for it? and also, i DOWNSHIFTS as youre going down the track? wouldnt that cause the RPM's to be really high and cause valve float?
Old Sep 3, 2008 | 11:43 AM
91RSLT1's Avatar
What mods do you have? What were you expecting to run? Was the GT stock? A little more info would be nice, the original post was vauge.
Old Sep 3, 2008 | 03:31 PM
Demon's Camaro's Avatar
That GT had to be stock and run by a bad driver. Most stock cars trap 98-100mph.
And yes a little more info on your setup.
Old Sep 3, 2008 | 05:35 PM
Jazsun's Avatar
Seems about right to me???
Old Sep 3, 2008 | 08:24 PM
MauriSSio's Avatar
96mph is a lil on the lower end of the scale for those mustangs but well within its range just like 100mph is on the high side. but it seems about right for both cars
Old Sep 5, 2008 | 11:41 AM
The Stang Only Had Exhaust Upgrade
Mine Has Forth Gen Locker W/3.42's
350 Injectors
Cold Air Intake Tube W Relocated Maf And Air Intake Sensor
2 3/4" High Flow Cat W/2 3/4" Intermediate Pipe To Flowmaster And Out Duel 5" Chrome Tips
Other Suspension Mods But Nothing To Help With Shifting Issue
Did More Inspection In My Tranny Found Springs On Govoner Are Wrong And Detent Cable Is Stretched Out
The Springs Are Not Letting It Shift Until Later
First To Second And Second To Third Rpm's Were Hitting 4800
And The Cable Is Not Adjusting Right If I Gave More Then 3/4 Throttle It Would While In Third It Kicked Down To Second The Rpm's Shot To 5500
Both Cases Were Keeping Me From Enjoying The Race
This Tranny Was A Stock Rebuild From A Friend For 100 Bucks I Got What I Payed For
Old Sep 5, 2008 | 11:48 AM
but i want more dammit!!!!!!!!for free of course
i've only spent 2,000 on the car including buying it and 400 was on the audio system
Old Sep 5, 2008 | 06:36 PM
Hit up car-part.com and you can find some pretty good deals there occasionally.
Old Sep 7, 2008 | 05:46 PM
TeamingTealZ28's Avatar
$400 on the audio system...and ur complaining about peformance?
Old Sep 9, 2008 | 05:50 AM
Marc 85Z28's Avatar
Why do you have "350 injectors" on your stock 305? The 85 TPI 305s ran well, and with 3.42 gears and some mild bolt-ons high 14s - 15 flat is easily possible - what did you run?
Old Sep 10, 2008 | 05:12 PM
yah 400 but that was pioneer cd player 5 way kenwood 6x9's 1600 watt 4 channel kenwood amp 1700 watt 2 channel kenwood sub amp and 2-12in subs sounds great but when i get out i need to let my ears adjust
Old Sep 10, 2008 | 05:40 PM
well my thoughts are as i can make mods a little at a time i should do it when i bought the car it wasn't running it had been sitting for 14 years and i needed to replace the injectors anyway so i did
i ran 15.6 @88 mph
Old Sep 11, 2008 | 09:54 AM
Marc 85Z28's Avatar
i ran 15.6 @88 mph
You are aware that the new injectors have hurt your performance right?
That car should be running closer to 15 flat in the low 90s
Old Sep 11, 2008 | 01:24 PM
i need to get a better tranny in it first and then see how it is(as posted on 9/5) i also have ads super chip to put in but one thing at a time and very slowly i might ad
