will 2002 z28 shocks and springs work on a 95 3.4?
I don't know if this has been ask before so forgive me the search didn't really pull any thing up unless I am blind all info would be app.
I have a 95 3.4 with 100k on the clock about time to change my shocks I believe lol lil teeth rattle going on here.
I have found a set of
2002 z28 shocks, will these be a direct swap into my car or is it not worth it?
I am just looking to get a lil bit more of a comfortible ride since this is just literally my beater...
edit: also are all the front hubs the same on these cars?
Re: will 2002 z28 shocks and springs work on a 95 3.4?
I agree with the shocks, but odds are the spring rates are different between a six cylinder car and an eight cylinder car. The spring will fit but if you put one from a 3.4 car on a Z-28 the car will sit lower.
While they fit, you must be careful. The 93-97 V8 springs take into account a heavier engine. Since the 98 and later V8 springs account for an aluminum block, it *might* work fine on a V6. Usually putting LS1 springs on an LT1 car results in a slightly lower front ride height, so with a V6 it should be close.
CamaroHeed
Mar 18, 2020 09:50 PM
