where is it located??
Old Aug 4, 2004 | 07:33 PM
flusz28's Avatar
where is the top shock bolt located at on my 94 z28 i have searched and found nothing on the inside at all..
Old Aug 4, 2004 | 08:38 PM
Sean94Z's Avatar
Re: where is it located??
The rear shock is under the carpet. Pull the carpet back behind the rear seat and there will be a rubber piece there, pull it up and the nut is under there.
The front shocks are bolted in place in the same manner, but, you have to pull the top a-arm off to get to it. Those 4 bolts come through in the engine bay.
--Sean
Old Aug 4, 2004 | 09:12 PM
flusz28's Avatar
hmm okay i did see a pad that must be where the bolt is
thanks sean
IndyZman
Oct 22, 2015 02:17 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
RobFlag
Aug 29, 2015 11:40 PM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
