Where is the adjustment "screw" for Koni adjustable shocks???
I just bought a '96 Z with Koni fully adjustable shocks. Where do I make adjustments on these shocks??? I have a round **** that the previous owner gave me to adjust it, but where does it go? Thanks!
Jeff
Jeff
Re: Where is the adjustment "screw" for Koni adjustable shocks???
The **** is for the rear shocks, you have to pull the carpet up and remove the foam caps and the adjustment is the top of the shock post. The fronts are a little tricky, you need a long pick to get at the **** which is just under the top of the tube. The adjuster has 6 or 8 holes which you turn with the pick to adjust them.
Hope this helps
J
Hope this helps
J
yeah, the carpet should have been cut in the rear for the rear adj (fold down seat)
for the fronts, i just got several sizes of round wire cotter pins from home depot, found a good size and bent it to adj the fronts. gotta lift the car though to access it thru the springs
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
