What exactly do shocks do?
Ive looked around and googled quite a bit as well as searched here and there. I don't know but for some reason i still dont understand exactly what they do and how they work. I feel stupid for this, but i cant seem to find a good easy explanation? Anyone got a good way to explain them?
Re: What exactly do shocks do?
yay! i get to answer first!!
a shock absorber reduces and eventually eliminates oscillations from the springs, if not for them your car would bounce up and down alot longer after it hit bumps
as for how they work
when u push down on the rod of a shock you decrease the volume inside the chamber, the fluid inside is a hydraulic fluid which means it wont change its volume very much, so if you decrease the volume of the chamber, the fluid must be displaced, it has to go somewhere, and so there are a few valves then open in the shock absorber, and allow the fluid to flow, at a specified rate
i'm probably not explaining this well, if i could draw a diagram that would be awesome
anyway, i tried
anyway, i tried
RUENUF
Mar 13, 2016 03:37 PM
karpetcm
Dec 16, 2015 09:07 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
