What do i need to lower the car?
Do i just need lowering springs, to lower my car?
Seems overly simple, if that's all i need.
Are these good enough, http://www.slickcar.com/productdetai...ProductID=1646 .
Can anyone recomend a cheap, fairly good brand?
Changing the springs will lower the car but will also compromise the handling and traction. Upgrading your shocks to work with the new springs is a good idea. Also if you're into drag racing, lowering the car promotes wheel hop. Adding lower control arm relocation brackets will correct the alignment of your lower control arms.
Eibach springs are worth the money. BMR has a good name, and very reputable. THere's another brand but I can't remember what it was.
You'll need LCA relocation brackets and an ADJ PanHard Bar. To reclaim lost LCA angles and the ADJ PHB to center the rear end.
I dunno so much about "comprimising" handling... My car handles like it's on RAILS now. I also have the Bilstein Re-valved shox. I also agree w/ switching the shox, you're in there anyway, on the fronts you have to take the spring off the shock... mind as well replace it unless you really feel like doing it AGAIN..
The rear springs and shox are cake to do. the fronts are a bit more involved. Check my link in sig. I have a shock/spring swap writeup in there on page 2.
As far as parts for good prices.... (you get what you pay for, keep that in mind)... Check these links.
www.thunderracing.com
www.tbyrnemotorsports.com
www.ls1speed.com
www.texas-speed.com
www.afterthoughtsauto.com
www.umiperformance.com
www.ws6project.com/user_stor/catalog
www.futralmotorsports.com
www.bmrfabrication.com
www.livernoismotorsports.com
www.ls1speed.com
www.texas-speed.com
Thanks man. Yeah for now i am just going for appearance. No funds for performance yet. Anyhow i only have the v6. Probably will put the v8 in there at some point.
I looked at your cardomain posting. The look of your car is pretty much what i'm after for mine.
What are the lowering specs on your car? Where did you get your lowering kit incl/ shox and how much was it. If you don't mind me asking.
And while we are at it, can you give me the specs on your wheels? I am interested in some Ruff racing wheels but i am unsure of the details i need for the wheels.
Thanks.
Thanks.
What do you "need"? Springs. If you want to do it all wrong and have a handling and riding mess
What do you need to do it properly? The correct springs (and many aren't), shocks valved to match those springs because the shocks are spring dampers, and an adjustable PHB since lowering the car results in the body mount moving relative to the axle mount and effectively shortens the PHB length shifting the axle to the right in the car.
And off all those companies, I carry the biggest choice in parts, and also specialize in handling and suspension above all.
Do you drive the car? Do you somehow leave the suspension at home when you do? Then your suspension is at work at all times. You don't need race parts. You do need the PHB (starting @ $99), some decent springs (not Ebay specials, $169 springs are worth what you pay for them), and if you are wise some shocks to control them. Do you have to do the shocks? No, but most folks who don't live to regret it since what makes the car worse than it really is to start with is the stock shocks, even on stock springs.
It's a bit expensive, but I used Air Ride Technologies' Shockwaves in front and CoolRide kit on the rear, topped off with the LevelPro system, and I absolutely looooove it. Took me a bit to get the adjustments just right, but now I can push a button on the dash and raise/lower/adjust ride quality if I wish. www.ridetech.com, if you'd like to visit.
Thanks for the headsup though.
Well, specifics are a two way street, and I can't give you any base on a paragraph on a forum.
Anyone that tells you they can give you a solid setup without speaking to you is.... well, I just won't do it.
