what causes a car to pull to the left or right ?
Old Mar 1, 2007 | 06:19 PM
Spllouder's Avatar
Well I replaced the tie rod ends and have had a toe in alignement . And still pulls to the left , Have to hold light steady pressure to the right on the steering wheel . ?
Would worn tires cause this much pull ? They are neer worn on the outher edge thread pattern . I have new tires on the way .
Will new front tires probaly fix the pull ? or did they not do the alignment right ? They did not give me a print out and forgot to ask .
also my sterring wheel has alot of play in it , Like it has slack in it before it catchs when i turn . also what about a rag joint does are cars have one ?
Old Mar 1, 2007 | 07:51 PM
respectirocz's Avatar
many things can cause a pull, if you had new tie rods installed and a wheel alignment an your getting excessive wear on the outer edges then you have bad camber which can cause a pull
Old Mar 3, 2007 | 02:17 PM
maro z28's Avatar
Is it set up with any caster lead?
Old Mar 3, 2007 | 09:48 PM
Spllouder's Avatar
the tire wear was from replacing the tie rod ends , and driving around for 500 miles before i got them aligned . i have new tires on the way , they will be here monday . ill see if new tires help .
Old Mar 3, 2007 | 10:25 PM
OBE1 95Z28's Avatar
You could always rotate your rear tires to the front and see if there is a change. Just because you had the car aligned, doesn't mean it was set correctly. I had to have a shop redo the alignment twice before they got it right (last time I'll use them).
Old Mar 7, 2007 | 07:33 PM
Spllouder's Avatar
Help !
I bought brand new nitto extreme T555 245/40/ZR18 Front tires . And now it pulls to the right . The oppsite way it was pulling with the old tires . But these new ties fix alot of my virbration in the front end and braking and steering . i had the rears balanced also .so what can cause this ? . SHould i bring it back to the shop i had it done at ? what should i say ? would they have a record of my print out . That they never gave me ?
Old Mar 8, 2007 | 05:23 PM
Dave1980's Avatar
I sure would bring it back. Could you possibly have something bent that could cause it to veer one way?
calaban
May 18, 2020 06:43 PM
CaRParts102
Dec 6, 2014 08:45 AM
1996LT1Z28
Dec 4, 2014 09:20 PM
owen66
Nov 30, 2014 04:21 PM
USAirman93
Nov 24, 2014 03:37 PM
