Well this SUCKS!!!!!!
Old Jul 2, 2005 | 10:28 PM
SpoolinV8ETR's Avatar
Ok, exactly 18 mins after we bought the 94 Formula. SHE had a encounter with a curb on the rear pass rim. Rim was trashed, got another rim but its bent but drivable. Something happened when the hit happened. Something made that pass rear brake wear ALOT faster then it should. Started to have metal from behind pad diging into the rotor. Got a new rotor and pads thinging that the shim or somethin wasnt right after the hit. Everything went back in was fine for a few weeks. Now tonight on the way home from the lake the same thing started to happen. Its the metal from behind where the pad USED to be diging into the new rotor. Any ideas? possible warped rotor again? what else?
Old Jul 2, 2005 | 11:01 PM
Plague's Avatar
Re: Well this SUCKS!!!!!!
could you have bent an axle or axle shaft? when I bought mine, I found this and had it replaced under warranty.
Old Jul 2, 2005 | 11:23 PM
chris5388's Avatar
I went through a very similar accident and my car was doing the same thing just replace the axle shaft and that should fix your problem
Old Jul 3, 2005 | 06:38 AM
87DJP2001's Avatar
New car, more power, and the back end wanted to come around. So it got away from you and something jumped infront of you=a bent axle and more damage then you like to admit. Now that Sucks from your inexperienced driving skills. Now that was a expensive driving lesson for you.
Old Jul 3, 2005 | 07:41 AM
Did you not read the post? I wasnt even in the same car! Why post stupid stuff like that?
Old Jul 3, 2005 | 11:07 AM
87DJP2001's Avatar
, Aways blame someone elae.
Old Jul 3, 2005 | 11:16 AM
Think what you will, i really dont care. The fact is in know what happened and your replys have nothin to do with helping me get it goin again. dont be a *****
Old Jul 3, 2005 | 12:03 PM
87DJP2001's Avatar
I am not the the one being nasty now. Just take it to a shop and get it fixed. its not a small change type repair that can get done by reading Posts.
It Sucks like you said so bite the bullet its going to cost you big bucks. .
Old Jul 4, 2005 | 10:16 AM
Big Bucks? umm no. Its called pull it into the garage and do it yourself. I had figured that it was a bent axle but wanted others opinions before i went a spent money on another one. you act like this is my first car or somethin. You shouldnt assume so much man. Only thing i have EVER taken my car to a shop for is alignment. EVERYTHING else i do myself.
Old Jul 4, 2005 | 11:18 AM
87DJP2001's Avatar
Well a big atta Boy for you. Also don't assume its only a bent axle shaft.
Old Jul 4, 2005 | 12:48 PM
Bud M's Avatar
What a jerk
Old Jul 4, 2005 | 05:22 PM
87DJP2001's Avatar
Originally Posted by Bud M
What a jerk
The truth hurts, if you drive a Camaro /Firebird LT1/LS1 and it hasn't happened to you take a
Old Jul 4, 2005 | 09:56 PM
respectirocz's Avatar
you're still a jerk, these forums are for helping each other, not useless critisizism
Jeff1904
Jun 5, 2016 05:00 PM
Kawi
Sep 28, 2015 09:01 AM
drt
Sep 27, 2015 04:39 PM
TRS Andrew
Jul 20, 2015 08:24 AM
NewsBot
May 10, 2015 08:10 AM
