Vette Calipers
Vette Calipers
i want to replace my camaro calipers with c5 corvette calipers, but keep the same oem rotors. i heard there are kits to do the conversion. how can i do this and is there any way to do this without spending alot of money. i will also be putting black z06 motorsport rims along with the calipers
IIRC they require a bracket because the bolt sizes are different but you won't see any benefit from running C5 rotors alone over LS1 rotors. The only other diff is the casting process and the LS1 calipers have larger pistons.
If you are after better braking get some better pads and fresh fluid. IMO C5 rotors on an otherwise stock LS1 system borders on rice.
where can i get that bracket or can i make one
Re'
But the guy is wanting to run C5 calipers vs. LS1 calipers on 12" rotors. He will see no difference.
carguyshu
Jan 22, 2017 11:19 AM
