vette calipers
Old May 14, 2004 | 06:47 PM
fatbody99's Avatar
vette calipers
I am wondering if you can put y2k vette front calipers on a stock 98-2002 camaro/firebird setup. I am not looking to switch to a bigger rotor i am just looking to set up to the two piston calipers that the y2k vettes have. Plus i like the apperance of the vette calipers. any feedback form people that have done this conversion would be greatly appreciated.
the kit i will proably be buying is the thunder racing brake kit that includes the power slot rotors, braided lines and hawk pads. I dont have the budget for a baer or willwood setup but definatly need some better braking power. as the birdman said "That stock **** stank".
Old May 14, 2004 | 09:25 PM
mitchntx's Avatar
The only potential issue I can see in this that the stock 98+ F-Body rotor is quite a bit thinner than the C5 rotor, almost a 1/4".
Consequently, the gap between the caliper pistons and the outer ears is wider on a C5 caliper than on an F-Body caliper.
So, the pistons in a C5 caliper on an F-Body rotor will move further out of the caliper housing when the pads get low than they normally would with a C5 rotor.
Will they pop out? Will they rock and stick in the cylinder bore? How much is too far out?
I dunno ...
Old May 15, 2004 | 07:21 AM
stevil's Avatar
Yeah, you would need to use C5 rotors also.
I converted, used special brackets that were designed to accept the C5 calipers. Not sure if they sell anything like that for the LS1 F-body? Also, the pads and lines would need to be C5 also.
My upgrade was very similar to a Baer kit, same basic parts and instructions. I went with the Vette stuff because the kit I made of used parts was pretty cheap. So unless somebody has an adapter kit for the C5 calipers, I'd go with aftermarket.
Old May 16, 2004 | 10:49 AM
Carlos01SS's Avatar
Where did you get those bracket at? Are they Bob Bishop brackets? If not, I need to know where to buy those brackets as well.
Old May 17, 2004 | 06:44 AM
mitchntx's Avatar
Bob is currently in a major redesign/marketing upgrade of his brackets. I've seen pics and they look great.
The only other vendor out there that I know of manufacturing adaptor brackets is LG Motorsports
Fastbird93
Apr 9, 2016 07:01 PM
Henson071
Sep 18, 2015 04:01 PM
force10
Jul 30, 2015 04:56 PM
alphaauto
Jul 26, 2015 04:40 PM
