V6 Springs in the Front?
Old Jun 5, 2010 | 02:58 PM
hozb817's Avatar
Exclamation V6 Springs in the Front?
Hey peeps,
I just did a V6 spring/drag shock install for the rear and the next step is the fronts. I didn't find anything on here about V6 springs in the front ... has anyone ever tried this before?
I am worried that they might be too soft (257 spring weight) and I am only comparing this to the QA1 Drag Springs (275 spring weight).
Any input, referrals, or links would be greatly appreciated.
Thank you
Old Jun 10, 2010 | 02:42 PM
bluz28's Avatar
I would say if you've dropped enough weight off the front you should be okay, otherwise stick with the stock spring rate, or greater.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
KYWes
Apr 3, 2015 07:59 PM
ModdedNerd
Dec 25, 2014 05:51 PM
