Upper shock mount help
Old Mar 18, 2007 | 03:32 PM
irocbsa's Avatar
This spring/shock/98+ brake install has quickly turned into mess. The upper shock bolt is rusted to the rod so both are turning together. With the way the mount it set up there really isn't a way to get an open ended wrech on there to spin it while I hold the rod. I looked up the upper shock mounts and they're $100 each! Does anyone have any suggestions? I would just cut the rod but there's no way to do it because of the spring.
Old Mar 18, 2007 | 03:36 PM
mdacton's Avatar
on the front of the car? are you swapping the struts also? if so cut the top off with a cutoff wheel...make sure the spring is compressed. The mounts don't cost that much....try somewhere else, I think they are around 45 per side
Old Mar 18, 2007 | 03:42 PM
irocbsa's Avatar
Yeah, front shock/spring/brake swap. I don't see how I can cut the rod off without ruining the mount.
You're right, I was looking at dealer parts. Autozone has them for $50 each.
Old Mar 18, 2007 | 03:45 PM
mdacton's Avatar
put the compresser on the spring and if you have new struts then take something like an angle grinder an just gring it where the stud comes thru on the top.....keep working it and you will get it ....ther is a odd shaped washer type thing under the....be sure te reuse that.
Its a common thing for them to be rusted up like that
Old Mar 18, 2007 | 04:51 PM
JimboManJones's Avatar
What that guy said, compress the spring alot, then slide the dust cover down and sawzall that bitch. Thats what I did, I couldn't even tell the damn thing was a nut anymore mine was so rusted.
Old Mar 18, 2007 | 06:46 PM
OBE1 95Z28's Avatar
When you're replacing the parts, apply some antiseize grease to the shock rod threads to prevent it from rusting.
Old Mar 18, 2007 | 07:43 PM
irocbsa's Avatar
Thanks folks. I got one of them off and I'm working on the next one. Time for a new cutoff wheel!
Old Mar 19, 2007 | 10:45 AM
NJLT1SS's Avatar
For the front shock mounts, I used a mix of anti seize and synthetic wheel bearing grease. I put a coating of it over the new nut and washer, and also used a generous amount through the mount itself. On one of my front shock assemblies, the top of the shock shaft was rusted to the mount itself, and wouldn’t even come apart after it was unbolted. Needless to say, that was a fun/terrifying experience getting that apart.
Nick
Old Mar 20, 2007 | 08:55 PM
irocbsa's Avatar
I am definitely planning on doing that. Needless to say, it has not been fun replacing the entire front suspension on a high mileage car. Anything I can do to make this easier the next time will be done. I have to wonder, how bad are northern cars? My car spent 99% of its life down south before I moved up to MI and it has still been a bear to take apart because of rusted bolts.
karpetcm
Dec 16, 2015 09:07 PM
Aug 5, 2015 08:35 AM
detroitmuscle
Jul 31, 2015 04:21 AM
realistyc
Jul 28, 2015 07:32 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
