upgrade sway bar/endlinks
Old Jul 9, 2012 | 11:19 PM
z28_4life's Avatar
I was going to upgrade my rear sway bar with a (22mm) out of a 3rd gen that I picked up for $10. The problem that I ran into is that I busted both bolts for the endlinks and one of the hanger bolts on the drivers side. So much for trying to go faster for cheap. I don't know if I have enough cash to upgrade to the umi rear drag bar set up. I did find that umi offers a sway bar instillation kit for a stock rear- $80.00. http://www.umiperformance.com/catalo...npqu5uvah07va0 Should I just go try and pull some endlinks out of a junkyard? My concern is that they'll bust in the same fashion.
Old Jul 10, 2012 | 11:29 AM
z28_4life's Avatar
Re: upgrade sway bar/endlinks
Ended up ordering Energy Suspension endlinks through Summit for $25 and a u-bolt through the steelership for $13.
Old Jul 10, 2012 | 02:56 PM
UMI Performance's Avatar
Former Vendor
Sorry for the delay. I'm sure you're good to go with the Energy end links and u-bolt from the factory.
If you choose to upgrade to our kit eventually, it has the great quality end links plus a massive mounting bracket which can handle anything you throw at it.
ramey
Old Jul 10, 2012 | 11:26 PM
z28_4life's Avatar
ramey
Ramey, thanks for the response. I do plan on ordering your sway bar eventually as it received the best reviews from everyone. At this point though the lt1 will just be idle in terms of modifications. I plan on picking up a 98-02 SS and swapping all the suspension components over and then selling the 94z. So far I have bmr boxed sfc's, bmr lca's, bmr relocation brackets, spohn body mount adjustable tq arm, spohn panhard bar, and my next purchase will probably be your umi drag sway bar. Again, appreciate the response.
Old Jul 12, 2012 | 09:21 PM
z28_4life's Avatar
I received my energy suspension endlinks in the mail today and I just wanted to make sure that Summit Racing sent me the right ones in the mail. The part number is 9.8125R. Please tell me this is correct.
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
