Tuneup now ABS problem
Old May 14, 2005 | 03:20 PM
phibud's Avatar
Well I did a basic tune-up (spark plugs/wires/fuel filter/oil change) and now I'm getting an ABS INOP service light. What could I have touched that could cause this? Thanks in advance.
Old May 17, 2005 | 05:29 AM
slopokrodrigez's Avatar
Re: Tuneup now ABS problem
One very common cause is having the plug wires too close to the ABS control wires. If that doesn't fix it, try having it scannned for DTC's
Old May 17, 2005 | 06:52 AM
94CamaroZ28's Avatar
Probably simple. Since the passenger side plug wires are such a PITA to get to , you probably unplugged the pass side ABS sensor wires. Trace it back from the pass front wheel, make sure it's still plugged in.
If that isn't it, do the same at the driver's side.
Old Jun 1, 2005 | 06:13 PM
phibud's Avatar
SOLVED Tuneup now ABS problem
It was the driver side plug wires. Rerouting them fixed the problem. Thanks all for the responses.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
